Powerfull Mobile Controller with CAN
moefit
Feb 2012
Tilburg
For many years we have been using IFM controllers. To our full satisfaction, I should say!
Currently we use the IFM CR0032 32 bit controller with a small number of I/O, 4 CAN-Busses and a pretty powerfull 32 bit processor (Infineon TriCore 150MHz).
Now we encountered the problem that the max CoDeSys program size is too small for us (limited to 1.25MB), also a more powerful processor would be very useful!
Does anyone have an interesting suggestion for us?
Found so much on internet, but hardly anything useful up to now...
Thanks!
Thanks!
I did not know that it is possible to exclude unused POUs! We did compare code size though, with and without some unused POUs, and we saw no difference. So it seems that this option is active already.
It helps a bit for us, but not much since we use 1 program for the complete series and optional functionality is (de)activated thru settings in the display.
Schneider's M340 has a native CanOpen port
Also as the M340 uses IEC programming language it should not be too hard to adapt your existing software
You will not have any problems with program size - just finished a project using an M340 to control a process plant (at least 40 PID control loops)
GeoffC thanks for your suggestion! Unfortunately it is not suitable for us, only 1 CAN-Bus and certainly not what I consider a mobile PLC.
Just wondering: does it take so much code to have 40 PID control loops? Suppose you use the PID controller as a function block?!
Yes I use the standard PID function block inside a defined function block. In fact I use defined function blocks for motor controllers, sequence controllers, analog input scaling conditioning and monitoring, interfacing to weighers, etc etc.
Impressive just how much code and io this plc can handle
The one plc controls the following
- 16 VSDs (ethernet interface)
- 30 DOL starters (profibus)
- 2 larger DOL starters (ethernet)
- 6 racks of IO (ethernet) including lots of control valves
- 6 weighers (ethernet)
- interfaces to 4 other M340s and a SIS (Safety Instrument System) over ethernet
Maybe I am a bit thick, but I spent ages trying to get the Combo Box in Exor JMobile to work, turns out that there is a trick that doesn't seem to...
644
Any users/experts out there? I have just spent the last while trying to make an animation property work. This project has a series of images...
1,546
Newbie question for an EXOR Jmobile javascript problem. I want to access at least one of the system values, but I am stumped on which javascript...
1,704
Hi all! I have an application where we have a industrial trailer (ie: connected to a commercial truck / cab). The trailer will have some...
1,185
I need an inexpensive PLC for home automation projects. I only need digital outputs and analog inputs. Pretty simple and slow process. Also, it...
33
12,175
