Problem with LG GMWIN v4.17
Angel Lopez
Dec 2002
La Victoria. Edo Aragua
Hi. I wrote a project for an LG GM6 Series PLC using GMWIN v4.17. It has 8 different instances (or sub-programs). I can succesfully compile each subprogram using "Compile" but when I use "Build all" to make the final PLC exe file, the linking process stops and GMWIN shows the message: "An error ocurred when link". No further information is shown at the Error/Warning Window. What is the problem? Has anybody experienced this kind of error before when using GMWIN? Any help is appreciated
Regards,
Angel Lopez
Hi. No, I'm using Win XP Pro. I finally contacted LG support team and they really didn't know what the problem was. I solved it by re-installing the application on the default directory at C\:, not in the Program Files directory as I did before. Weird, but it actually worked. I'm not sure GMWIN has been tested on Vista, so give a try on XP Pro
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
40
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
171
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
135
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
144
Hi all. Simple as simple can be, I don't understand what's happening. I'm toggling he OSR on, GX_LUB_PUMP1_LEAD should switch. It doesn't. The...
27
668
