Profibus configuration using SST module
ddot61
Jul 2005
Georgia
Has anyone created a Profibus network using a SST module for an A/B Contrologix processor with old Siemens ET200L I/O?
Any help would be very much appreciated.
Thanks,
Todd
If you have the GSD files, then you should have no problem adding them to the
SST Profibus Configuration
Version 3.10.0.0
In my version, I cannot locate your Siemens part. (I don't have an updated library though)
Once you locate the GSD, (if available) then just simply add it to your topic in the configuration software.
(I have located the drivers, but you need to provide more info)
See link.
http://support.automation.siemens.c...cslib.csinfo&lang=de&objid=113440&caller=view
Simply download, and insert.
Hi, I have interfaced my product (which uses a proprietary serial RS 232 protocol) to a PROFIBUS-DP network using a PROFIBUS-DP Serial Gateway...
6,043
Hi My devices are as follows: S7-300 > CPU 315-2DP (6ES7 315-3Fx-0AB0) PROFIBUS CP342-5 (3425DA02-0XE0) ASi CP343-2...
4,979
Hi All, got an issue with a PLC5 Profibus adapter card and it looks as though I need some legacy software (Local Station Manager) to configure the...
735
Hi everyone, I'm trying to learn how to make hardware configuration. I have an IM on profibus. I added the whole group (I dragged the marked taxed...
1,174
I'm trying to setup a Profibus link between a CTI 2500-C200 PLC and a MTL 8507-BI-DP. I'm using FasTrack 505 Workshop V5.10. I've tried a few...
1,258
