Programming cable for CQM1H
The CPM1-CIF01 has the "old style / large" peripheral port connector on the pigtail and the Omron pin out DB9 on the front.
This unit works with the CN220-EU cable to communicate with CPM series, CQM1 and C200HS and newer processors. It will not work with the original C200H cpu.
You can use the two cables your Omron dealer quoted, those will work for the CQM1H (original post).
You could also use the cable below from GeniusInTraining. This is a single cable, USB to mini peripheral port.
https://www.plccable.com/omron-plc-cable-usb-cs1w-cn226-cs1wcn226-usb-version/
Above will work for CQM1H.
You would need the cable below for the CPM1A to connect to the peripheral port.
https://www.plccable.com/omron-plc-cable-usb-version-of-cqm1-cif02-usb-cif02/
Or this cable to connect to the DB9 on the CIF01.
https://www.plccable.com/omron-plc-cable-usb-c200hs-cn220-eu/
Sorry, not able to help on the Logo.
Hope this helps.
Thanks Jeff!! (great support as always)
Kal, we stopped selling the Logo cable, we had to many issues with them also thanks for the order we will ship today
Are these CQM1H obsolete?
The cable I ordered and promptly received (thanks geniusintraining :)) have a connector unlikely to be on the old CPU I need to connect to. It goes back a long way.
I don't have picture of the port but I'm starting to wondered if I need an adapter or another cable.
In all of google and other search engines......not a single image of the CPU with the peripheral door open to view the port, amazing.
Sometimes you need a 'Link Adapter' but I think on that CPU using the Peripheral Port you would need the CN226, looks like a mini HDMI connector, I think you bought one of them
Awesome!!
Thanks Mark!
kalabdel,
The above image should help to understand the difference in ports between the CQM1 and CQM1H.
Both have been discontinued by Omron.
CQM1 discontinued in 2001, CQM1H in 2012.
Hope this will help.
Both cables worked well. I installed the drivers at home and which made my life very easy on site. Interestingly enough, I plugged the CN226 into a CS1H-CPU66H thinking I was working on the machine that had the CQM1H and uploaded the program with no issues. Bonus.
Thanks Mark.
Kal
The CIF31 is not cheap but is a little ripper. I have tried just about everything on the market for USB/serial and it is the only one that has never caused a problem to be honest - with any equipment. Have also purchased some USB/RS485 and USB/RS422 converters that had FTDI chips in them - they rip!
Thanks Mark.
Kal
Your welcome glad you got everything working, thanks for the orders!
Big thanks to Jeff great support, as always!
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
135
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
176
1203-USB I can't find it for sale new so I assume it's no longer made? Used, folks want no less than $1k USD for it missing all the cables and in...
2,083
Hey Guys I am trying to figure out the correct cable to use to connect from my laptop to this Panelview using panelbuilder32. I was sure I had...
2,049
I need to emergency fabricate a cable to program a Parker 690+ VFD. Part # CM351909 I believe. RJ6 on one end, DB9 on the other. I cannot find the...
2,306
