Pulse Train Signals for Motor Control
Andreik
Mar 2009
Makati City
80
Good day,
I would like to ask something about selecting the right IAI PCON Pulse Train Motor Driver for my PLC which is Keyence KV-40DT(P). My application is very simple. I have a 1-axis RoboCylinder and I want to run it Forward/Reverse through Pulse Output.
IAI PCON has 2 Pulse Train Models, PL & PO:
1) PL - Differential Receiver Method (Differential line driver), 200kpps
2) PO - Open Collector,60kpps
Keyence PLC has 1 Pulse Output: 1 axis, 50 kHz max.
Now, my question is this:
1) What is the difference between Differential and Open Collector Pulse Train and what is applicable for the Keyence PLC?
2) Is kpps, Kilo Pulse Per Second?
3) Wiring between PLC and Motor Controller.
Sorry, I'm just a beginner in Motion Control. Thank you very much, hope you can help me.
Sincerely,
Andrei K.
Uhmmm... Can anyone just give me an explanation about the Differential and Open Collector Pulse Train. I'd appreciate any help.
Thanks,
Andrei K.
I would like a sanity check on an application i am working on. I have a proximity switch counting pulses with a Mark/space ratio of 1:1 on a...
1,882
Hello, I am using pulse train output to a stepper driver to control a stepper motor. It seems to work fine except when I use a Control Stop...
3,333
Hello All I have a system using the ML 1400 plc. I have an encoder on HSC:1 input 4. I want to pass this signal out on a FET output to another...
1,961
Dear Expert, I am doing troubleshooting positioning control in Servo amplifier Mitsubishi MR-J3-A. He get pulse train input from FX1N. PLC...
1,671
Hi, i already make a program CP1E with pulse train ouput (PLS2) to control stepper vexta. Can i use work online simulator in cx-programmer to see...
1,468
