PV800 to ML1100 via RS232
ThomasGruetter
Jan 2010
Florida
63
PLC 1763-L16AWA Micrologix 1100 with PVC 2711C-T6C.
Replacing the HMI with the PV800 2711R-T7T.
I have taken a PV Component program and converted it to the PV800 in Connected Components Workbench. I thought this would work right away using the existing RS232 connection. Nope.
I need to know how to configure the Serial connection on the PV800. In don't find anything in the maintenance screen nor in the CCW software. How does this work?
I found the issue, I was looking under communication on the CCW program which is for downloading with RSLinx. I attached a screen shot picture to show
that clicking on the HMI opens a communication window - all clear now.
As the title says, I'm using CCW with a PV800 (and Micro850). I've made a scheduler in which a user can choose a month, day (1-31), hour (0-23)...
531
Scenario: This is for a system that has a PV800 user interface (connected to a Micro850 PLC) programmed with CCW. There are various control...
557
Hi All I have a Panelview 800 HMI hooked up to a Micrologix 1400 controller. I have communication and have the screen set up with some...
935
I have a USB port RFID Scanner I am using for badging users into certain access levels in an HMI. I know that I could create a 'login' button that...
613
Hi Friends, I am trying to connect MLX1400 over RS232 serial communication with PV800. I am not sure where I am going wrong, the PV800 doesn't...
960
