Quickpanel Conection Error 02:FF
MisaMagna
Nov 2016
Valencia
Hello colleagues! I have a Total Control's Quickpanel 9" Monochrome Screen Model QPI211. I want to connect to an Allen Bradley PLC SLC 500 CPU 5/04 using DH+, in the Quick Designer project setup I have set the communication protocol AB SLC DH485, then in protocol configuration I have put the same number in both the Source ID (Screen) and the Destination ID (PLC) to avoid the error "02: FF PLC IS NOT CONECTED" I tried with several numbers but I get the error again.
By the way the screen has already been connected previously with the PLC since it has a loaded program that I could not recover, that is why I did another program but I get the error. How can I solve the problem? Thanks you all.
I doubt that the above link will help with your problem.
DH45 is different than DH+
For DH+ one needs a DH+ port which in the QuickPanel world is an optional piece of hardware. If you are lucky you may find one on eBay but you will likely have better success changing the PLS to DH45.
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
346
Dear colleagues, hello to everybody! I have a problem with Quickpanel IC754VBI06SFD-GF Proficy Machine Edition Runtime 6.5 QuickPanel View V2.00...
666
Dear guys, I am not a programmer but I can do simple things myself. I'm stuck with the following. if I want to extract a value from my rx3i...
46
4,794
does anyone know if you can make a graphical panel with the quickpanel+ 7inch that you can only open with a password? for example a panel where...
1,827
Hi all, I need some help in uploading of QuickPanel gp570-sc21 program to PC. I load from QP to PC the project through the working HMI-CAB-C49...
2,030
