Random messages in Panasonic GT11
Sep 2007
St. Petersburg
Hello!
I have been tasked to display some information (weather, for example) from PC on Panasonic GT11 display. Generally, i'm a C++ programmer and very far from PLC. GT11 is the choice of customer. I used "General-purpose serial communication" mode. I create some base screen in GTWIN utility where i placed data part from part library. Next i connect from my program to RS422 port (COM.port) of GT11 and change memory that associated with data part. Data have been changing. It's good. But i also need to display some random messages from my program. I found message part in part library, but it can display only predefined messages... What can i do?
Thank you!
You can write data to the PLC regester and after you can make CT11 display this data. There is a flow message parts in GT11.
Hope it helps.
Create your custom message line(s) from single-digit DATA objects of ASCII type.
When without frames, they will look as a straight line.
Link each object to own data register.
Define [Address: low>high] and [Word: low>high] in the object options.
After that you will be able to send ASCII character code to each from your PC program.
Flow message will not do the job beacuse also must be preprogrammed into GT.
Looking for some advice for backing up the programs on a bunch of old random PLCs. All I'm really concerned about is getting the program out of...
43
4,729
We have several Powerflex 4M (22F-D013N114) VFD’s controlled by compactlogix PLC’s. Control is simple, a run and direction signal with the speed...
1,537
Hi all, I know this is a PLC forum, but I know there is a gread deal of knowlege on drives as well. This drive has been running on stone...
896
Hey folks, I was just wondering what thoughts were about a completely 100% random number generator. I looked on The Google but didn't really open...
54
16,569
Hello Friends I need to activate random outputs (0-9) and ask for random inputs (0-9). I have created in s71200 a program to generate a random...
4,738
