Raspberry PI & Snap7
boneless
Feb 2008
OKC
1,628
Hi all,
I am just starting out with playing with the Raspberry PI and the Snap7 libraries. I was hoping there are more users here that would like to collaborate and share their findings.
I have not gotten any further than running the supplied programs, but I like what I see so far.
I have two main goals:
1. Make a cheap interface for the client to connect to remotely and visualize, control variables.
2. Log data to excel.
Thank you, I know you can run CodeSYS on the PI, but I was specifically asking for people having experience with Snap7.
I did not know about Snap 7 - I 've downloaded it and now I have something to play with next week while stuck out of town. (Thanks!).
Do you have any particular application in mind ?
A specific thing I am wanting to do is log values from a small movable boiler installation and from that information calculate efficiency.
I think it would be rather simple to log these values directly into excel and automatically send these sheets by email or make them available on a ftp server.
Help
If you need any help with that, I'm am busy with such things, logging PLC data in csv files with dotNet.
Thanks! I haven't had much time to play around to much, but please do share :)
I'm busy with a website where I will put screenshots of all the applications that I've made in dotNet. Logging to csv is one of them. Gimme 1 more week and I'll put it online.
Regards,
C
Application
I've written an application with libnodave that logs a variable with timestamp in a datagrid and that can be exported into csv.
What you need is logging directly rows in a csv file, right ?
Yeah that sound great!
Take your time, I have not been in a rush myself so I am not trying to rush you :)
This is a screenshot of the tag logger that can be exported to csv:
http://www.automationsoftware.be/variablelogger.html
Logging directly to csv with appending in the csv is something I will finish this week. I will do this also with a trigger bit, every time I see rising edge I will append in the csv.
Regards,
C
I haven't done much with it but I have played with a few projects using Snap7. Doing some basic pulling of data from 300 and 1500 series PLCs. It worked great (keep in mind I am not a computer programmer just a tinkerer :)
Anyways I would gladly help if there is anything I can do.
Libnodave
Hello,
I did not use Snap7 for my projects, I use Libnodave.
You have any ideas for projects ?
Projects that I'm working @:
- Batch execution
- Calendar triggering
Kind regards,
Combo
Automatically sending out emails on certain triggers (analog and digital)?
Receiving SP with email/text?
Looking promising so far! Thanks for sharing
Has anyone ever tried to integrate a Raspberry Pi to a Fanuc robot? I have this idea that I want to try out but I need to write integers from a...
1,558
Hello, I have been getting more and more requests for Real Time Clock (RTC) sensitive automation from my clients. I know that there is a Modbus...
2,759
Hello! I have seen some stuff with people using a raspberry pi running some sort of open PLC software to run some test examples. Has anyone...
25
6,558
I have a customer who has 20 of our systems using PanelView Plus 7 Performance Series A terminals. With how hard it is to find printer nowadays...
1,628
Hey guys, I'm new to PLC, Although I was wondering if I could establish a handshake between the CJ2M and Raspberry pi over Ethernet...
2,402
