Red Lion/CompactLogix addressing question
Zlinger
Mar 2014
AZ
36
I am using a Red Lion G310 with a CompactLogix PLC and the "Allen-Bradley Native Tags via L5K File Enhanced" driver. I can import and use the tags just fine from the L5K file, but I am wondering if you can use the Allen Bradley hardware addressing also. I can't seem to figure it out.
For example, I can set an indicator to be controlled by [PLC1.ExampleTag], but it doesn't seem to work if I use [PLC1.Local:1:I.Data.0]. Is there some special syntax that I need to use, or is this just not possible?
Thanks for any help.
I don't think it is possible to address them directly. I always create Aliases for them.
Zlinger, I would recommend buffering the I/O tags regardless as the IO scan is asynchronous to the PLC scan. Specifically in your case, I believe the colon ":" in the tag name is what hangs up Crimson software.
This is the set-up we have, and we recently lost comms to two devices on this PLC. After replacing the red lion and copying in another identical...
1,862
Hi everyone! I'm trying to "bridge" some variables between a CompactLogix and an OPC UA-server using a Red Lion DA10D protocol converter. I got...
1,350
Hi all, I'm designing a project using a CompactLogix L33ER PLC, connected via Ethernet to several PowerFlex 525 VFDs and a Red Lion HMI. As far as...
3,917
Hey guys, I am trying to make an Allen Bradley Compactlogix and a Modicon Quantum talk to each other using a Red Lion Data Station. So far I've...
3,012
I am having some fits with my new project. Here are the details of the system: PLC: 1769-L33ER v21.11 RsLogix Studio V21 HMI: G308C100 Crimson...
22
9,465
