yeah it doesnt seem to have helped much. I pretty much have to hit every charachter on the keyboard 2-3 times to get it to take. I also find that it is much worse if I use my finger as opposed to my nail or a stylus.
Any updates on this issue?yeah it doesnt seem to have helped much. I pretty much have to hit every charachter on the keyboard 2-3 times to get it to take. I also find that it is much worse if I use my finger as opposed to my nail or a stylus.
That's a good question, but any selectable keypad size should work, or it should be removed from the options, right?I can't help but wonder what size keypad he is using.
It should work, but if the nail or stylus works, maybe fingers are too fat...
no its definitely not a fat finger issue. it works better with a stylus or nail, but it will still miss 2 or so presses before registering the touch.
at this point we are going to send to red lion for analysis.
If you haven't already sent the unit to us one more thing you can test is to put the touch test primitive on the screen. Then touch on the screen and you should see a dot. Let me know how close the dot is to where you are touching.
Jeremy
it looks like the dot is exactly where I press, it just seems that the screen is not sensing the touches consistently.
still waiting on a rma from the distributor.
Do you have to touch it multiple times on the touch test page or does it respond properly there?
That information will help Redlion diagnose the problem.
Have you sent them your database yet?
yes even using a stylus I have to press in the same spot 2-3 times to get it to register a touch.
