Here we go!
You are looking at a top view.
The bales are loaded into the machine with a loader in the 18 bale configuration you see in green. They are loaded 3 high, a total of 54 bales. You can only see 18. They are really loaded to the left and ram #1 has already extended and pushed the bales to the right. It then opens back up to create enough room to load another 54 bales while machine is strapping. Ram #1 is of no concern to me.
Now
Ram#2 extends 16", stops, strapper #1 straps.
Now
Ram#3 extends 18", stops, Strapper #2 straps.
Ram#3 extends 12", stops, strapper #2 straps.
Ram#3 extends 18", stops, returns to full retract.
Now the lifting section squeezes the 18 bale package and lifts it into the air 56". It is now waiting for the next package.
Now
Ram#2 extends 16" stops, strapper #1 straps.
Ram#2 extends 8" stops, returns to full retract
Now
Ram#3 extends 18", stops and stays.
Now lifter unsqueezes package #1 and drops it onto package #2
Ram#3 extends to full extend, stops, returns to full retract. This pushes the 2 packages clear of the lifting section.
The process continues as long as there are bales in the machine.
I hope this sheds some light. I should have started with this drawing and explanation. Prox's, encoder, cable transducer?
You guys tell me now what the best would be considering I have already built the rams.
One last thing, all measurements above are full movement from a compound ram. I will probably mount devices in association with the cylinders. Divide all numbers in half to get actual cylinder ram movement.
