Rotary cam switch - Balluff
Avatar_41
Aug 2019
Istanbul
96
Hello to everyone. There is an inductive sensor to control the angle on the "Balluff bsw 819" rotary cam switch in a 1000 ton mechanical press. However, the part where the sensor was attached was broken, they replaced it with something else, the original is missing and the part code etc. in the technical document material list of the machine. does not exist. Balluff, on the other hand, said that the piece was not his own production. Where can I find a sensor attachment apparatus that I can attach such an angular adjustment to?
This is not a PLC question, but maybe one of you have seen a product like I am looking for. I have a portable pneumatic misting system that is...
577
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
477
I've noticed a strange behavior with certain rotary disconnects. We all know that, if installed correctly, the disconnect interlocks with the door...
1,470
I'm looking for electric rotary actuator with field bus.
1,176
Hi, everyone: I tried to understand the basic knowledge of CIP motion control axis configuration. we have one rotary axis (kinetix350) in our...
1,128
