Rotary Screw Compressor Control
I_Automation
Jun 2020
Detroit, Michigan USA
1,648
Got a customer with a Chinese air compressor, 240V, 15HP.
The present control of the entire system is inside their VFD. It controls the motor speed and oil injection to compress with an analog pressure sensor input, along with the buttons and a small display pad.
Bad tech support and a timed shutdown for maintenance that is really too soon and the customer wants to know if I can replace it with a A-B PowerFlex I have on the shelf and make my own control.
Has anyone here built a compressor control panel for a rotary screw compressor?
Am I in for a nightmare or could this be simple?
A small PLC and a small HMI, used an Idec system in a class a few years ago with a small HMI I think would be perfect if this is possible.
EDIT: Forgive all the typos, my adult fingers and these phone keyboards don't get along
Easy set up.
If you've got a small plc that can run a basic pid loop, an a couple of outputs for oil injection based on hours run. No problem.
This is not a PLC question, but maybe one of you have seen a product like I am looking for. I have a portable pneumatic misting system that is...
581
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
479
I've noticed a strange behavior with certain rotary disconnects. We all know that, if installed correctly, the disconnect interlocks with the door...
1,477
I'm looking for electric rotary actuator with field bus.
1,178
Hi, everyone: I tried to understand the basic knowledge of CIP motion control axis configuration. we have one rotary axis (kinetix350) in our...
1,133
