Operaghost
In RSLinx on the RSWho window right click on the driver (such as AB_ETH-1). Do this on the window on the left hand side. Select Remove.
This will remove the history of all devices on the driver. The next time you browse that network only the ones actually present will appear. Don't worry if the driver disappears from the window. Just close the window and reopen it and it will re-appear.
If you only need to remove one or two, you can also just click on the ones with the red "X" and press the delete key on your keyboard.
OG
OG
