RSLogix 5000 array tags (I/O points)
Vuli
Mar 2006
Toronto
Hi
I am using ControlLogix L32E and
RSLogix 5000 V13 (Structured Text).
I was wandering if its possible to assign IO points to tag array.
example:
Tag Name: IOArray
Data Type: BOOL[16]
Output card: 1769-IQ16/A (16 outputs) in slot 1
Is it possible to assign an IO point to each element of IOArray.
End result would be something like this:
IOArray[0] is alias for Local:1:O.Data.0
IOArray[1] is alias for Local:1:O.Data.1
IOArray[2] is alias for Local:1:O.Data.2
makes sense ... (?)
If this is not possible what do you think would be the best
way to loop through IO points (I have about 200 :( ).
Thanx
Vuli
Yes...
1) Create a user defined type, containing an array of bools. (Ex. UDT: BitArray, with one entry 'Bits' of type 'BOOL[32]')
2) Create a tag of that type (Ex: TestBitArray of type BitArray)
3) Use the COP instruction to copy your base input tag (ex: Local:5:I.Data) to your UDT Tag (Ex: TestBitArray), with Length set to the number of bits to copy (8/16/32/12)
Hey all, I am trying to figure out how to import some alarm messages without having to type them all in by hand. They are in the format of an...
1,128
Hello i have been trying to figure out a good way to take hex and convert it to an array of SINT[]. Here is what my failed attempt looks like.
1,273
I have a subroutine that gets called to copy a UDT In an array to a tag. This subroutine will be called around once per minute and has been...
2,120
Hello! I have an application where I can only have 3 pumps running out of 6. I load the pumpRunning bits into an array. What I need to do is...
3,133
Hello Currently have a project in which I have to find the highest value in a dint array. Once the highest value is found I will have to move...
20
11,486
