RSLogix Tag Nomenclature Confusion
blupony96
Mar 2014
Central Illinois
I am trying to learn the logic of a process at my new job. There are tag names that I can't make sense of because they end with _xva, _xvb, _xvu and so on and so forth. I know they are associated with motion, but I need to make better sense of them. There are no descriptors. What do they mean and is there a resource available that I can reference?
Tags can be whatever the programmer wants them to be. There is nothing in Logix that dictates a tagname. You hope that the programming has some obvious naming structure that applies to the equipment they are programming, however that's never a given.
You either figure out the interpretation buy digesting the code and making sense of it. Or call/email the original equipment supplier to discuss your questions.
Hi. I came into a problem that was buried in my memory. I had a list of modifications to do on 2 RSLogix programs. So I tapped in the IP...
1,098
I want to ask about this tag that is in RSLogix 5000: datatype: AB:PowerFlex525V_EENET_Drive:I:0 and I want to create a new tag(instance of...
2,373
Has anyone experienced the following issue on RSLogix5000 (currently on V16) I have a PLC program that has been running on a site for a number...
1,611
Hi All, I have a new 5 PLC system. Each has the same firmware revision. Each PLC has the same User Defined UDT for Safety Tags. PLC1 reads from...
2,019
Hello, What is the Problem: I have an old version of projects with all the tags' descriptions and a new one without them. I know how to...
3,170
