pietervdb
Hello,
I'm programming my first S7 DS program, with a little help of the "S7 Distributed Safety Getting Started".
I have a 317F-2PN/DP with a ET200S IM151-3 HF and a 4F-DI/3F-DO io module.
The program is very simple for the moment.
I've got one Emergency Stop (1oo2 input), and two outputs. One immediately off when the ES is interrupted and one after 1 second. At I12.0 i've got a normal DI for the reset function.
It's possible to compile and download the safety program but i still got an error on the fail safe module. See screenshot.
In the hardware module DI channel 0,4 is activated, everything else deactivated. For the output DO channels 0 and 1 are active. channel 2 is deactivated.
So, I need a little help here.
Probably i'm forgetting some but i can't find it.
