Scanport Over Controlnet
toopster
Oct 2009
inverness
Hello,
I are currently in the process of phasing in upgrades to our systems, replacing PLC5-80C's with CLX controllers (it just cost us £12K for a replacement PLC5 controller!!!). We currently have a mixture of Flex IO over dual redundant ControlNet and 1336 drives over ControlNet via a 1974-ACNR15 and 1203-FM1 scanport module. We have many drives so changing out nearly 60 drives of various sizes up to 60kw cannot be done on one foul swoop!!
Program conversions are progressing well however I cannot seem to setup communication to the 1203-FM1 scanport modules. There is no module profile in logix5000 rev16 for this module so I have tried using a generic flex module profile and using the same input/output/config/status parameters as the module previously had in Networx. (i/p-6words,o/p-5words,config-5-words,status-3words) I cannot communicate with these settings. There is a knowledgebase article that explains how to do this using CIP My question is, can you communicate with a 1336 drive via a 1203-FM1 over controlnet with a CLX controller?
The knowledgebase article on this is rather old and suggests to use an unscheduled CIP method, this does not seem a solution to me as it suggests that as it is unscheduled, there is no safe-off options available in the event of errors with PLC, communications etc.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/20027
Regards
Colin
o_O
I'm trying to control a 1305 over controlnet with a PLC-5/20C. I have made the network connections and scheduled the network but when I look at...
1,902
Hi Everyone, We do have several cabinets with SLC5/03 CPU's and two SCANport modules, each. 5 ports are being used, communicating with 1305 VFDs...
2,478
I have a dozen AB overloads and softstarters presently communicating to Prosoft SCANport-to-Modbus modules. These then connect to Modbus Plus via...
2,471
Hello, I have a Allen Bradley SMC Dialog Plus that i communicate to through a Scanport 1203-EN1 and i'm getting this error below I/O Faulted...
1,330
Possible dumb question alert here. Is the 1203-SM1 module for Scanport communication "plug and play" as long as the DIP switches are set...
1,917
