SCANport to Modbus to Modbus Plus
bluenoser337
Apr 2003
Nova Scotia
391
I have a dozen AB overloads and softstarters presently communicating to Prosoft SCANport-to-Modbus modules. These then connect to Modbus Plus via bridge modules and on to a Momentum MB+ CPU base. The CPU is being changed to Ethernet and I am looking for something to connect directly from SCANport to Ethernet (preferably Modbus TCP, but that's asking a lot). Allen Bradley have discontinued their SCANport to Ethernet/IP module (1203-EN1) and Prosoft no longer makes any module for SCANport. Any suggestions besides replacing the overloads and ss? Thanks!!
:geek:
Removed the Modbus network. Added a Current Transducer to each starter and a regular overload to the ones that weren't softstarters. Changed to non-networked control using digital PLC inputs and outputs and now reading current on an analog input using the CT. Simple and works great! :p Same could be done for 1336 drives...use digital control and read amps from VSD's analog out terminals.
:cry:
Hi Everyone, We do have several cabinets with SLC5/03 CPU's and two SCANport modules, each. 5 ports are being used, communicating with 1305 VFDs...
2,474
Hello, I have a Allen Bradley SMC Dialog Plus that i communicate to through a Scanport 1203-EN1 and i'm getting this error below I/O Faulted...
1,321
Possible dumb question alert here. Is the 1203-SM1 module for Scanport communication "plug and play" as long as the DIP switches are set...
1,910
Hello, I are currently in the process of phasing in upgrades to our systems, replacing PLC5-80C's with CLX controllers (it just cost us £12K for a...
1,676
Hello Upgrading to a ControlLogix processor using existing 1746 I/O (If it ain't broke why fix it?) Main Rack 0 - 13 Slot Chassis Expansion...
2,679
