schneider plc
zahid iqbal
Nov 2012
peshawar
hay everyone
i am working on tsx micro 3721101 schneider plc. i did not know about the programming software name and programming cable. if any one have any information then please reply me. i am waiting..
thanks
Hello Zahid
you need PL7 Pro 4.4 or PL7 Junior software and the cable reference is TSXPCX3030 for this plc
Look for the nearest Schneider reprentative in your side and ask them to quote these items for you
Hope this can help
Best regards
Hello zahid
yes just a trouble with omron cpm2a programm upload
I get the following error message "the UM is protected and programm can't be uloaded".There's no dipswitches with kind of plc,as omron CJ series and I'm stuck
Best regards
Password protection is the problem. You need the password to access the program - there are 2 levels.
Hello Bobb, thanks for your reply
the problem is that there's no prompt for password input
I get only the message prompt I mentionned
In addition may I add that there is upper memory protection available and task read protection. Either or both can be applied.
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
123
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
171
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
161
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
348
Hi All, We are planning Establish communication between Power Energy Meter (Schneider PM5320) with Rockwell PLC. I am unable to get the Assembly...
765
