Search result text display
NAthangrave04
Apr 2018
Ontario
Just curious:
When I tried to ctrl-F and looked for a keyword, it only manage to display a few words.
I've always wondered if its possible for the search result window to display more, and use the empty space for remaining comment line.
Just like the screenshot, the right side of the search result is pretty much unused.
The search result is blue - so it's an active link to the found object, just click it to see the location and the full text of the search object.
You would not want your search results window bloated with the whole of the rung description.
Oops! Sorry. I was thinking of the error list when you verify the controller. My bad.
No probs... i guess it's been a busy day, lol
either way, the "results" window gives you the link to the relevant piece of code, or description, without bloating the results listing...
I just got home after a 10 day paper mill outage. I should know better than to think before I sleep in my own bed tonight....
Actually, my job was to add logic for two valves and then support the BMS guys while they were checking interlocks on a recovery boiler, and anything else that came up in the mill during startup. I call it "high speed standby". If they're willing to pay, I'm willing to stay.
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
258
I have an InTouch HMI that has PID parameters. I need to find what the PID values were in the past. I have backups from the past, but none...
48
5,577
Good morning folks, I'm on a quest to find all of the references to the CurrentUserHasCode function in our project. I have the project...
436
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,031
Hello all, Some of you may be familiar with the RAM searching program for Windows computers, Cheat Engine. You can search RAM directly for...
746
