Selection of Manual-Automatic from PLC inputs and also from WinCC Flex 2005‏
interlock
May 2011
Middle East
29
Dear All,
Consider a selector switch is located at the electrical panel and it is wired to the PLC at I0.5 (When I0.5 is low = Manual , when I0.5= high = Auto).
Also, WinCC has configured the touch panel with a button authorizing selection of Manual and Automatic.
How to make sure the safety? Just by providing interlocks in the program???
What is normally done or what is the normal practice when programming such applications?
PLease bear with these "low-level" questions .... I'm still getting on with WinCC Flex.
Regards
Dear All,
Regards
If you want to switch equally both from the HMI and the panel, you will have to use pushbusttons preferably with LEDs, and pulses from the HMI. A selector can not be used.
Kalle
I need an enclosure for wifi access points that will be outdoors. The antennas will mount outside the box but everything else inside. Standard...
157
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
109
Dear Members; We are going to design a Simplex Control System With Following: 1. 24 Digital Inputs (SIL 2) 2. 24 Digital Outputs (SIL 2) 3. 4...
1,135
Respected Members; I am going to design the PLC control system. The requirement as under: 1. Input/ Out put modules are SIL 2 certified. 24...
417
Hello, Not able to find Modicon DO modules BMXDDO3202 in EcoStructure Control expert V15 catalogue. But i can find only MBXDDO3202K. Can you...
472
