SERCOS / Digital vs External Analog Servos?
kdcui
Dec 2007
USA
386
I'm relatively new to motion control and I am reading up on the various choices of Rockwell / AB hardware selection.
Everything I've seen so far has been integrated Kinetix drives over SERCOS. I've noticed that some instructions in the Motion Instruction Set are specific for external analog servo drives or drives on a CIP comms axis.
I am wondering how the Kinetix drives differ from external servos (say a servo over a analog interface (1756-M0XAE).
What do the integrated servos do that the external / analog servos can't (besides higher resolution).
well, with the integrated solution, you get an electric servo drive, and you can select a variety of motors (including linear). Logix knows all that it needs to know about the particular motor and hence the setup is relatively quick and painless.
THe analog servo can drive pretty much any device that takes an analog command. I've used it with valves, hydraulic motors, etc...
The structure (and some commands) will be different based on your selection. For example (MDO instruction sends a voltage to the output and as such is not available for an electrical motor)
Good afternoon all, We have a carton machine with 7 Ultra3000 sercos drives controlling various servo motors. From what I understand, It has...
446
The CP led indicator flashes red for a split second then back to green. Other two led indicators stay green at all times. I’ve checked...
1,514
Hi you all!!! How do i download the backup in a drive ultra 3000 sercos? I tried to do this through the ultraware software, but it...
1,057
Trying to configure the 2nd drive on this machine. It is being difficult. I have the gains speed encoder data all with good data. when I try to...
1,855
Hi all, My first post 🍻. I'm Jay from the UK. We are in the process of upgrading our hardware to 1756-L83ES, most of our lines use...
1,677
