Set Max Number of S7 and MPI connections on PLC
Rusty_K
Mar 2004
Norway
73
Hello,
Wondering if anyone here remembers how to set the maximum number of S7 & MPI connections allowed for a PLC. I feel like it should be in the Hardware config of either the CPU or the CP Card but I can't seem to find it. I've fully done this before so I know it exists somewhere, I just cant remember where exactly....very frustrating!!!
Thank you kindly for your help
Cheers!
R.K.
do you mean reserved connection resourses(in connection tab of the pls'c properties) or something else?
No, I believe it sets the maximum number of concurrent S7 connections to the PLC...From memory, I believe the default value is 8.
You cannot set the maximum number of connections. This is a fixed property of each CPU or CP.
What you can do is to reserve connection types.
I.e. There are maybe max 8 connections available in all. By setting OP connections to 3, you reserve 3 out of 8 for this purpose for example.
However, it is possible to attach 4 OPs if there is an additional connection available apart from the 3 reserved.
Hello, Would anyone happen to know what parameter in a PowerFlex 525 to have the drive trip if the torque permissive set point is exceeded...
449
Hello, I have an unused IC200CPUE05 Versamax PLC which I assume to be completely default settings. I'm trying to set an IP and download...
2,167
Hi everybody, I am trying to set PCL time and date from iFix VBA code and I don't even know where to start. Does anybody know the command or...
2,652
Hey All, Im new to this (hence the name) can someone direct me in the right direction? I am using a slc500 (fixed 20 I/o) with pic 1747...
1,749
Dear Sirs / Experts We have encountered a "Nmax TRIP" on our EVS9327-ES LENZE servo drive. I have tried resetting from PC by changing the...
3,140
