Setup Kepserver with Foxrtu station or isagraf
Mike_ant
May 2017
USA
hello guys
i would love to read data from a foxboro rtu sdc2200 (i have all softs installed on same virtual machine )
i'm using kepserverex as opc server and no success until now
i'm able to read data from other softs like excel , plcs, tristation 1131 , but couldn't with foxrtu station or isagraf 5.13
i don't know i need to install a driver or something similar in order to make it possible to simulate
see images
http://imgur.com/a/7Wgy3
thanks in advance
http://www.plctalk.net/qanda/showthread.php?t=110156
Let's reset your question, What exactly is your setup?
Don't assume anything about what we know about about setup.
- How are you able to read data from the RTU, what physical and protocol path?
- Is the Kepware you are using licensed for DNP and is it in Demo mode only?
- You said can't read from FoxRTU or Isagraf, but able to read from other devices and software so what is the data-path, who is the master and who is the slave? Show us the diagram.
Hi again ,
regarding softs i could read data from (Excell via DDE client ) and tristation 1131 via Triconext ethernet
when it comes to Foxrtu station you can check pictures in previous topic and these ones
http://imgur.com/a/jfFXw
when it comes to Slave ip and Port on foxrtu station there is no configuration on how to set up a port number
that version of kepserver is a demo
all what i want to achieve is simulation ( everything is installed on same virtual machine )
thanks in advance
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
55
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
70
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
160
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
689
Hi everyone, I am currently working on a AB 193-EDN and i am trying to figure out this "Average %FLA", it keeps showing 70-75 but my clamp meter...
99
