Siemens I-device
Purrdie
Mar 2011
Las Piñas
34
Hi guys,
I have a system with several s7-1200 PLCs with identical program.
I want to connect the s7-1200 PLCs to one s7-1500 via profinet, which means, I need to configure the s7-1200 as I-device. the s7-1200 will be the IO-device and the s7-1500, the IO-Controller.
Now, what I want to know is, if do I need to generate individual GSD files for each s7-1200 or I can use one GSD file for all s7-1200?
Thanks and Regards.
You can use the same GSD file for all the S7-1200.
edit: WHen you add the GSD file for each S7-1200 to the S7-1500 you have to assign a unique device name, and it must match the one you actually assign to the actual S7-1200 PLCs.
I wouldn't do it that way
Just integrate 1200 and 1500 in the same project. Make the 1200 an I device with a check box. Then assign I and Q data. Done
Hi JRW,
Thanks for the reply. Actually, the S7-1200 is a different contractor so I cannot integrate it in my TIA project. We requested a GSD file from them. Now I want to make sure what are the configurations that I need to consider to be able to communicate with them.
@JesperMP: OK. I will check on the device name. Hopefully they assign a different device name for each 1200 PLCs.
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
127
I'm new to S7. Whenever I do a "Download to device", this window appears. I've seen some online tutorials and this doesn't happen for them, so my...
1,111
I've just created a small program and saved it. Then I clicked on the 'Download to device' icon and this dialogue box appeared. Do I need to...
20
1,458
Trying to integrate a new S7-1500 to an existing S7-300 PLC. Using the S7-1500 as an I/O Device. Trying to send some simple boolean tags between...
1,105
Ciao guys, I'm not used to program on Siemens PLCs, but sometimes I have to. I'm experiencing a strange problem when I try to connect to a PLC...
3,951
