siemens MP370 (multi panel display)
naishadgosai
Aug 2005
surat,gujarat
39
hi to all,
i have a MP 370 HMI of siemens make, which is already programmed and running ok.
now i want to upload program from it, so its possible to upload if ,if yes than how pls mention the procedure.
NOTE ::::its programmed by third party so, i haven't original backup.
It is possible to upload a program from a Siemens HMI with "ProSave" This give you a file with the ".PSB" extension. It is however NOT possible to make changes of any kind. The ".PSB" file cannot be opened in ProTool, it can only be downloaded to another panel.
Uploads can therefore only be used as backup.
If the original "protool" project has had the "upload" checkbox ticked, then you can upload from the panel through protool. Never used it personally and i believe this is only possible with the more expensive WinCE panels.
If its a backup only you require, then use prosave as previously suggested.
regards
STL
mp370
hi there
if want to have back-up then do as Mr. Garcia has said.
If you want to any modification in the exsisting set-up then u need to have the orignal copy.
If you have PLC software and is completely through with it then you can make your own version and download it, but this is tougher part.
You need just a simple RS232 cable for downloading your project in MP-370.
regards
manmeet
mohamed,
start a new thread.
And specify the EXACT type of the operator panel,
and state a bit more about what is not working,
and any other information yiu have.
Hi guys, While trying to upgrade a Siemens MP370, it hung somewhere in the process and gets about halfway through the creation of its disk...
2,784
Need to put in a new touchscreen digitizer. Does anyone know the procedure or how difficult this might be? Have never taken one apart, so I don't...
1,412
Hi all, I have a problem with a Siemens MP370 touch panel. The original panel had a fault with the touch sensor, so a new unit was purchased to...
7,327
Hey i want to make a trend on a Siemens MP370 15 TOUCH 6AV6545-0DB10-0AX0 And need a storage card MP370 have USB-PC-card and CF-card, i wonder...
5,119
Hi all, I have a Siemens MP 370 15" touch HMI connected to an S7300 over MPI.. I have the source code application in WinCC 2005. I am trying to...
1,944
