sectoreng01
OP
- Join Date
- Mar 2004
- Posts
- 4
and that slick way would be...
Originally posted by Richard.Christian:
What else are they going to use it for? Programming a Siemens PLC !!
Or! Create a very small partition (5 - 10Mb) on your hard drive with XP, ghost or drive image, install Siemens and any other (AB?) licence info onto that new partition then backup that drive with the ghost or drive image to CD! this way you don’t have to restore your whole operating system when you have a problem! simply restore the partition.stevo said:As regarding Backup I simply image my hard drive using Drive Image. In the event of a emergency i simply restore from CD. I also keep all my project files on a seperate partition to the bootable windows partition. I've worked closely with siemens service guys in the past and thats the method they Use.
Steve.
aslan said:Can you tell us your S5 program version. After that maybe I can help you. If you have windows version it is not difficult to make authorization disk.
