Siemens SM331 Analogue Input modules
ProDave
Apr 2002
32
I have gradually been selling off some old stock of Siemens S7 PLC modules.
I have had an enquiry. The customer wants a 6ES7-331-7KF02-0AB0
I have a 6ES7-331-7KF01-0AB0
What is the difference? Both are described as AI 8 X 12 bit.
I suspect the part No he wants is just a newer version. Does anyone know exactly what differences there are, and most important will the one I have plug in and work?
Also what is a fair second hand price for this module?
Yes, but what I was getting at, is could my potential customer just insert the module I have in place of the (presumably faulty) one it is replacing WITHOUT having to make any programming changes?
If I 7KF01 was my only spare I would just swop it but selling it ,it would be good policy to change the hardware config.
btw . I replace a faulty 7KF01 with a 7KF02 without change hardware config but then you would except later versions to work
The 7KF01 has weaker current source for 2 wire analog inputs. 7KF02 is a superior device. Isolation between groups is also improved.
Nick
Hello Experts, I need your help about this issue of mine about my Siemens Analog Input Card SM331 having SF LED lit. I know this is system fault...
4,492
Hello All, Want to know what should be the correct setting for the Measuring range for connecting this instruments to my AI Card? So I am...
2,400
Hello Experts, I am going to be integrating an AI module into an existing panel and wants to know what should be measuring range setting when i...
1,887
Hello guys, I have a thermocouple with a green wire which measures a temperature 0-1100 degrees. I dont have any information, only the color of...
7,162
Hello everybody I'm working on a project using SM331 2AI board (6ES7 331-7KB02-0AB0). Describing the hardware, the SM331 is connected on a...
5,870
