Siemens Step 7 Holiday Puzzle - 2008
L D[AR2P#0.0]
Nov 2006
UK
6,699
Attached is a Step 7 project that has been run using PLCSIM. Currently the project flashes Q0.0
One line in one of the blocks would need to be modified to flash Q0.1 instead - which line in which block ?
Please send answers by PM
One line in one of the blocks... and everything written in STL...
This is really a tough one....
Don't be mad if maybe i give a part of the sollution
in your code after you strip the TOD you do this
= [AR1,P#8.0]
Can i assume that this is the value that you take to FC5.
And is it correct to assume that it is the value out of byte 6 (see attachment)
I can make the Q1 flash but probably not in the correct way hehe
Got Struck up in the first step itself.
My PLCSIM does not shows Q0.0 blinking, PLC is permanently in STARTUP mode.On doing the Cold Restart PLC comes in RUN mode but again without Q0.0 blinking !!
Is it a part of the puzzle or what? I do not see others complaining of this !
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
264
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
566
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
706
Hello, We monitor the temperature of a pipe via a 4-20mA temperature transducer. This goes into DB135(Read Analog Inputs). The issue I have is the...
640
Please excuse the basic question, but I've never worked on Step 7 before (until now, only dealt with Mitsubishi Q-series PLCs)... What is the...
16
3,376
