Simatic Manager - MMC
jeilers
Oct 2006
rotterdam
Hi everybody,
On my company a lot of people are working with laptops which have a MMC-card reader integrated. I noticed that when i inserted a Siemens MMC card, it became visible in the Windows file-system, but when i wanted to open it from the Simatic Manager this wasnt possible. The usual option (File->S7 Memory Card->Open) was greyed out. This isnt a problem when you are using a Siemens Field PG.
Does anyone know if this problem can be solved at all? I know that the cardreaders are hardware-compatible so i suspect it is only a driver-issue.
Thanks, Jos
If you are lucky, you didnt trash the MMC card when you inserted it in the standard PC card reader.
Whatever you do, do not write to it or format it in a regular card reader.
Remove it from the PC.
You need a Siemens MMC card prommer. To write to the card.
I dont have a MMC prommer as it is not critically needed.
You need it to install new firmware in the CPUs, or if you have to send a MMC card somewhere by mail.
One should ask Siemens why they chose a format that looks like a Multimedia Card, and is spelled "MMC" (for Micro Memory Card) when it is actually something different.
Hi, All I have been tasked with uploading configs from two running Siemens PLCs. One from an ET200 and one from a S7-300. I have no real previous...
1,394
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
327
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
282
Hello all. I went to a customers location, uploaded from the S7-300 (CPU312) and performed a save, performed some work then came back to the shop...
619
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
768
