simatic s7 PC ADAPTER USB
i had try this pc adapter usb on window 32bit (which is desktop) and i found it work nicely
also same goes to mithsu and omron usb-cif02..
just wanna confirm does this mean this 2 item cant be used with window 64bit.
and really bangging my head .wonder why does mitshubshi can work on 64bit and 32 bit window.
Hello there, I also bought PC Adapter USB A2 recently. I am using Windows XP SP3. I need to connect Simatic Manager with the same. Now the...
5,726
Hi there! I use a Simatic PC Adapter 6ES7 972-0CB20-0XA0 with TIA Portal V11 SP2 but cannot connect to an S7-314C 2 DP. It worked a week ago...
6,667
There is no “USB” item in the Set PG/PC Interface – Local Connection – Connection to, only serial port RS-232 (COM3) connection is there. I...
16,973
Hello, I know that I can program Simatic panels indirectly via the S7 PLC. We get 24V and 5V from the PLC's MPI port and distribute it to the...
3,734
greetz, i have a siemens simatic s7 pc adapter usb (serial 6es7 972-0cb20-0xa0) and plan on connecting it to the siemens PLCs in a goss web press...
6,623
