SimaticNet Tag Syntax
Pete_S
Mar 2015
Portland Maine
76
I am trying to read tags in a DB on a S71500 controller using SimaticNet V12. I have PC station configured in project as V8.2 so I can use DA connection and I can browse to tags in the \SYM group. What I would like to do is add tags in OPC Scout that read using DBX,X1.0 and DBX,B1.0 syntax. Is this possible? Or can someone tell me what syntax I would have to use to read from another client? I can connect to the OPC.SimaticNET server with Kepserver OPC quick client but unsure groups that i would need to use to get to tag level. Thanks in advance for any suggestions.
If you have setup an S7 connection, then instead of [SYM] you should browse to [S7].
Example:
MyConnection[S7]DB10.DBX1.0, BOOL, 1
(this from memory, I cannot tell it exactly since I have left my PC in the hands of the IT department for today).
Also, be sure that the DBs in question are non-optimised, and that access via PUT-GET is enabled.
Example:
Thanks JesperMP. Would you be willing to provide valid syntax when you get your PC back? DB's are not optimized and I have Put/Get access enabled.
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
219
Hello to all, I have an application that consists of S7-300 with PLC program created in STEP7 Simatic Manager (v5.6 SP2) with SIMATIC NET PC SW...
24
2,851
I have been experimenting with Siemens OPC Server. I successfully installed SimaticNet on a Laptop and set it up as a PC Station using the Siemens...
2,921
Hello, I have a problem to do some tests on a system I'm developing. Working with industrial IT and sometimes have to deal with some automation...
1,440
Hello All, I'm working on a service application to read data remotly from a SimaticNET OPC Server. All DCOM settings are correct, since I can...
1,221
