Simulation
Gerbert
Jan 2004
Dear all,
I'm working on a simulation of a car. I use a regular editor/engine combination for that, and commercial usb devices like a steering wheel end pedals. But, for more realism, I would like to add a real set-up of a car (found at a junkyard) as 'interface'. So, no more easy usb devices... Should I use various components (like potmeters) and connect them to a PC using a PLC ? Or are there other easier solutions ? Is a PCI PLC card affordable ?
Help would be very appreciated,
Gerbert
Now THIS sounds fun !
Even though it would be possible to use a PLC and interface it with a PC etc. etc. , why not just open up that USB steering wheel and pedal you have allready, and exchange the plastic components with some genuine car parts.
The other thing will cost you a LOT of time and money.
help me
** How is working PLC **
** How manny is Money sall PLC **
** You send Exsample please; **
Hi Jesper,
true! But, there are some technical constraints. My logitech steering wheel doesn't do as many rotations as the real thing. And I have no idea how to resolve that... The pedals would do fine, so I could use those. Buttons etc are also difficult, maybe you know some usb device with a lot of buttons ? Could use a joystick with a lot them, mmmmm...
Gerbert
A gear..... simple and effective. Well, that is an option. And certainly more simple than a PLC etc.
Gerbert
90
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
77
hello every one. i'm new to tiaportal, i have created new project and HMI screen the program works fine with PLC-sim, but when i try to cntrol the...
424
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
651
I use the HMI simulation as our production lines are pretty big and we've put an upgrade in over the last couple of months and I've used it most...
737
