Slc 500 address
Bling_bling
Nov 2016
Ohio
23
So yesterday I used a laptop which had the addresses set to address to the sum bit in the data table instead of the word bit. Example O:1/48 instead of O:3/15 (I hope I'm explaining this correctly)
How is this changed?
You can set the display to show binary data type in that way. By setting it up under "view properties" "address display". See picture.
I didn't know that could be done for "output" data type.
Can you post the program, zip it first.
What software are you using?
A customer asked if I could change an output address in a SLC 500 that he thinks is bad. I've not worked with that PLC before, so I asked him to...
2,619
hello everyone, i am using a panelview 600 communicating with an slc 5/05 thro rs 232 port. I have misplaced the ip address of the processor...
4,199
How do you assign an IP address to Ethernet module for SLC500 ?
14,562
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
1,018
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
792
