slc 500 ip address retrieval
urvinder_pal
Mar 2009
surrey
38
hello everyone,
i am using a panelview 600 communicating with an slc 5/05 thro rs 232 port. I have misplaced the ip address of the processor and now i cannot establish the communication with it thro the ethernet port. Is it any way to find out the ip address of the processor.
thanks
kanwar
hello everyone,
thanks
kanwar
First, do you have the offline file (.RSS) if so check the port's configuration.
Go online with the processor thru it's serial port and check the channel configuration. You will have to disconnect the PV momentarily.
A customer asked if I could change an output address in a SLC 500 that he thinks is bad. I've not worked with that PLC before, so I asked him to...
2,611
So yesterday I used a laptop which had the addresses set to address to the sum bit in the data table instead of the word bit. Example O:1/48...
1,873
How do you assign an IP address to Ethernet module for SLC500 ?
14,544
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
998
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
785
