SLC 500 High Speed Counter Card
mjkoc518
Dec 2004
46
At my job on a specific machine the A+,A-,B+,B- inputs to a High Speed Counter Card are all connected in Series with Resistors. I don't remember the resistance value of the resistors but the moral of my question is, what are the resistors for?
Your encoders are probably open-collector output types, and require "pull-up resistors" so that the when the transistor is OFF the voltage is "pulled up" to the 24v supply.
I am assuming here the resistors are not actually in series with the input, but are actually wired from the 24v supply to the input.
HSCE Series resistors
The 1746-HSCE was designed as a 5v Differential Line Receiver input. If your encoder has a higher level signal, 12v or 24v......the resistors act as current limiters, protecting the HSCE input circuit from high currents associated with the non-5V DLD inputs. The User's Manual for this card indicate the resistor size per the encoder signal voltage.
Hello! We have a drum rotation machine controlled by a AB SLC 500. The drum rotation inputs comes from a encoder into a 1746-HSCE. We are using 2...
1,137
2,253
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
976
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
774
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,365
