Slc 500 or 5000
Feb 2007
Oklahoma
277
I was wondering how long the Slc500s and Micrologix PLCs will be around. Does Rockwell Automation plan on phasing out the 500s and Micrologixs any time soon? Should I focus totally on 5000 or is it best to also continue learning about the Rslogix 500. We have both 500 and 5000 at work. I just do not want to waste too much time if they are going to phase out Rslogix 500 soon. Thank you all for your help.
Sincerely
Maintenance Man
I wouldn't be too concerned about the SLC/Micro line. They are still releasing new hardware for Micrologix.
Consider this, PLC2 has been obsolete for some time now and I still have to deal with them once in a while.
You should continue learning as much as you can...
Thank you very much dmroeder for your help. I am happy to know that I can continue to learn RsLogix500 knowing that it will be around for some time to come.:site::nodi:
Is it possible to add 1747-L541C to RS5000 so I can use message to get some float values? I am using 1761-ENI/D for Ethernet conversion on the...
9,066
Good afternoon! I would like to know if there is anyone in the group who could help me !!!! Next I have a compaclogix 5000 with two serial ports...
146,392
Anyone find a way to do DDV command on a Logix 5000 platform? I can't figure out how the double divide is calculating. Looks like hoodoo voodoo!
4,469
I have a complex SLC program that used doubel index addressing. For example N[N47:162]:[N47:1]. When it coverts through the AB conversion tool...
4,069
Is their a way to send data back and forth between these two processors?
38
14,740
