SLC and the PIC
mikeyk
Nov 2008
mass
I have a SLC503 and I wish to talk to it without using the PIC. Does anyone know how to do this? Also the 503 has a program in it already that has to be erased. How do I do that?
Any help will be appreciated. Thanks in advance.
use the Rs232 port and in rslinxs do a auto-configure then go online with rslogix 500 and under the comm tab there should be a option to erase memory.
You can use a 1747-cp3 cable on the 9pin connector..
To clear everything you can unplug the battery and short the pins gnd and vbb on the back of the CPU... search the site just to make sure but I think thats what they are
This is correct - short the VBB and GND pins for about 30 seconds. This will default the processor.
Hello, I'm trying to communicate my 1747-L532 ser B with os#1747-OS300 A 3 using 1747-PIC. My power supply is a P1 and 7 slot rack. But RSLinx...
6,324
hi . my probli i connect the lap top with 1747-pic a to slc 5\01 but came to me ( no commnucation ) what i do in this case .:)
4,278
Will the 1747-pic driver work with windows xp? We have a cpu fault on a 1747-l40a and I need to upload the program. When I configure the pic it...
6,023
Looking for knowledge if it is possible to connect a PC through a 1747-PIC ser A to a SLC 5/04 8 pin mini din (DH485). Everything I have looked...
2,639
A few days back Bubba and Cletus connected to a fixed IO SLC500 through a PIC using a desktop with a serial port. As soon as they plugged it in...
3,500
