SLC, HSCE card and rate type flowmeter
Carkington
Dec 2006
Portland OREGON
Does anyone here have any experience with the 1746 HSCE card on an SLC 503?
I read the user and installation manuals and got some info. But I don't know enough about high speed counters to get it all.
An SLC 5/03 has a 1746-HSCE card installed. I am using a flow meter to measure water flow in a process. It is a paddle wheel type and outputs a variable frequency 3 to 200 hertz signal proportional to flow rate. We are trying to measure an amount of water used in a batch process.
Set me straight if I am on the wrong track here. We are using old, salvaged equipment and the accountant is a tightwad.
Specific questions.
1) What input terminals do I use on the HSCE? The flowmeter needs 8 to 35 vdc on the (+) leg with a resistor for current limiting, with the negative side on the (-) leg.
2) Rate or range?
3) Count up using a ring counter I think. And reset to '0' once the batch add of water is done.
I understand how the input words work. This is described in the user manual. Also M0 and M1 words are described. What I am lost on is the wiring and setup to use.
Anyone?
Thanks in advance.
Hello, Problem:The accumlator value in the counter card freezes when my encoder wheel spins beyond 4.5K Hz. Ofcourse the rate would be 0 at that...
2,292
Hi, I have been asked to modify a machine as follows. On site there is a SLC 5/02 plc (1996), with spare slots. I am using RS logix 500 V5.20...
3,490
Hello, First I looked at Manuel and Plctalk but I did not find or maybe not understand. How I can connect ''HTL / Push pull-24 volt encoder'' to...
2,526
Processor Error Message: G file configuration error.. user program G file size exceeds capacity of the module. I cannot seem to find any data...
2,048
How do I keep track of the counts for this encoder in programming. I am using logics 500. The encoder PPR is 1000.
2,905
