slc5/05 dh485 and enet?
keving9
Mar 2004
33
We have a DH485 network with a SLC5/03, 2 SLC5/02 and 2 PV1400. There is a desire to put this information on the plant ethernet for remote monitoring. Can this be done by replacing the 5/03 with a 5/05 to get the ethernet connection and continue to do the other communications on the DH485 net?
Thanks.
Yes.
It might be cheaper to use a 1761-NET-ENI ( Ethernet to Serial) and connect this to the SLC5/03's serial port. The SLC5/05 is the better choice though.
I assume the 1761 net-eni would become another node on the dh485 net and would slower than the SLC5/05 option. Correct?
NET-ENI doesn't become another node. It simply converts the DF1 port to an Ethernet protocol.
If the DH-485 network is already in place, it's probably more cost-effective to get a single SLC 5/05 and a NET-AIC to use as a DH-485 pass-through. I have a 3-node DH-485 network connected this way and it works great. Just program the SLC 5/05 to read MSG from the nodes that have the data you want and store it locally for retreival or monitoring.
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,335
Hey all, long time reader but first time poster here. I've been tasked with an odd one and was wondering if anyone else had experience in this...
17
5,365
Hi all, I'm working on a project replacing a failed SLC5/03 with a new ML1400. I've gotten the program updated and working, all the IO changed...
1,536
Hi everyone, I am new to this PLC forum and I have a question about this new project I am working on. I have a testing machine running on an old...
1,896
Dear, I have to communicate my SLC 5/04 CPU channel0 ,configured as DH485, i have an ethernet interface 1761 NET ENIW. I have read how to...
3,926
