Slow PI reaction time???
RPax
Feb 2004
125
Hi, not to familiar with tuning loops but was wondering if I could get some advise, recommended liturature or a link to a another similiar question posted on the site. I have a PI temperature control loop which we're commisioning. At the moment the valve closes when the Process variable goes behond the setpoint and opens when below the setpoint.
However,the loop reacts very slow. For instance, when the valve proceeds or ramps to a close when the temperature is to high, the temperature still rises until the effect of the valve closing comes into affect. The same happens when temperature is low. It has come to the stage where the control valve is practically just opening and closing in the loop without much control. Is there anyway to controlling such a senario. Would changing the scan rate of the PI help. Appreciate any help on this. Thanks
Normally what I do is first set the I to 0.
Gradually increase the P until the loop begins to oscillate, control valve will go to 100% to 0% to 100%. Divide the value of P by 2 and enter that.
Allow the loop to stablize, with P only the actual temperature and setpoint temperature should be close with an offset of a few degrees. Gradually introduce I, start with 0.001 and monitor how the loop behaves. Gradually increase the amount of I and monitor. Once the P and I appear to accomplish what you desired, change the setpoint to ensure the PI loop responds as desired.
Its a start
Ian
PI (or PID) control is poorly suited for systems with long response delays. It is very difficult to tune them to get reasonable response and simultaneously avoid hunting.
Look at feed forward control or else a floating control (like a thermostat) system. It will probably give tighter control and better stability.
It isn't clear to me what is slow.
Is it the plant time constant(s), dead time or the PI gains are too small?
RPax needs to find the plant gain, time constants(s) and dead time. The rest will be easy then unless the dead time is large relative to the other plant time constants.
I also recommend studying the control guru suite.
I finally found the time to play with a Banner DXM700 and a few DX80N2Q45R thru-beam photoswitches. Frankly, I expected it to go much smoother...
878
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
156
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
90
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
75
Hi. Importing a 2014 aapck in 2023: no problem using it, adding windows, works very well, no problem whatsoever. Creating a new project: as...
755
