Slow reaction time - Banner DXM700-B1R3
rguimond
Jul 2009
Escuminac
666
I finally found the time to play with a Banner DXM700 and a few DX80N2Q45R thru-beam photoswitches. Frankly, I expected it to go much smoother than it has been...
I plan to use these wireless switches to replaced wired on a turntable to avoid flexing and eventual failure of cables
Binding the swithes to the DSM was easy enough, but the reaction time between a status change at the switch and the DSM is agonizingly slow. I can view the internal resisters on the LCD display as I break the thru-beam. It takes between eight and 15 seconds for the DXM to detect that change, and it is no better if I select "Cyclical" or "On change of local register data" as the frequency of RTU writing
So far, I have tried the following:
  • Reset the DXM for factory defaults
  • Reflashed with latest firmware
  • Used a different sensor as Node 1
  • Changed the batteries in the sensors
    Eliminated three of the four switches
  • Connected the DXM to a different power supply
  • Moved my test rig to a location where there are no 2.4GHz signals
I have a call in to my local Banner rep, but I'm hoping someone here has a solution.
Hi, not to familiar with tuning loops but was wondering if I could get some advise, recommended liturature or a link to a another similiar...
3,416
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
156
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
90
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
75
Hi. Importing a 2014 aapck in 2023: no problem using it, adding windows, works very well, no problem whatsoever. Creating a new project: as...
755
