Slow shutdown times with RA software
phuz
Jun 2008
Mohnton, PA
1,044
Just curious if anyone else experiences slow shutdowns (1 min. or greater) after installing RA software. I've been plagued by this for about two years and it was after installing a bunch of new RA software, but I haven't been able to isolate it to a specific one, yet. Using shutdown trackers, I've narrowed it down a to service that is taking a long time to stop. Doesn't help much, though.
I assume you are referring to the windows operation system
Try shutting down RSLinx before you shut down the computer
it a Windows communication thing. if a packet is received while Windows is shutting is will delay the shutdown to process the received packet I have see very long delays even 3 to 4 min.
Yes, windows, specifically Windows 7.
Unfortunately, I've tried shutting down t RSLinx, and the laptop is disconnected from any network so packet reception is not an issue.
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
156
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
90
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
75
Hi. Importing a 2014 aapck in 2023: no problem using it, adding windows, works very well, no problem whatsoever. Creating a new project: as...
755
I am having a weird experience using KepwareEx6 as an OPC Server for a set of SLC processors where the tag data is not updating remotely at the...
577
