Someone just had to ask.
Status
Not open for further replies.
Peter wrote:
"There are trolls and ignorant people here that attack anything they don't understand without making the effort to understand what they are being told. There real problem is that these people have not had the proper education to understand the simplest of concepts. Hopefully you will do better."
Now there is something we can agree on Peter. It's hard to believe that you have finally come to the place where you believe Fluid Power Training is not anywhere near what it should be. Or at least I believe that is waht you meant when you wrote: "There real problem is that these people have not had the proper education to understand the simplest of concepts."
How else could you be so adamant against We the, UNTRAINED, in a regimen we fell into by default.
Don't give up trying to teach the UNTRAINED though. Someday it may pay off if you don't waiver. Fluid Power may come out of the Dark Ages someday if enough ignorance is shown that no one uses it anymore.
Peter Nachtwey said:
You are not clear
Qe and Qr being the flow from the pump or the flow from the extend and retract side of the piston?
You are correct - I wasn't sufficiently clear. The e and r refer to the extend and retract side of the piston, or as us old timers called them the rod end and cap end of the cylinder. The flow referenced is the flow in and out of the cylinder. V is the velocity of the piston. V = Qe/Ae = Qr/Ar.
I read what Tom has to say. I think there is hope for Tom unlike others posting here. Tom is still and engineer, I hope.
Well, Peter, that's what it says on my business card and my PE license anyway!
[quote
Yes, that is part of the proof of the VCCM equation. Keep going, you will soon come to the same conclusion as to why the speed doesn't double when the supply pressure doubles. In stead it is a square root function.
I am more impressed if the PE believes in Newton's law of motion rather than "flow makes it go". Did you see the part in one of my PDFs about
ΔPressure=β*ΔVolume/Volume
If you let ΔVolume=Flow-Velocoty*Area then you can see that If Velocity=Flow/Area that ΔPressure must be 0. You can say that Velocity=Flow/Area only when ΔPressure needs to be 0 but that doesn't make the system go. There needs to be a net force to make it go. It may keep the system going under ideal conditions. It depends on other factors.
The VCCM equation provides the maximum steady state velocity IF the system has the ability to accelerate to that velocity. The differential equations explain how the system will accelerate or decelerate. The available flow makes no differences as long as there is enough flow. The speed at which the sum of forces is 0 is the steady state speed. The flow will then fill the volume using Velocity=Flow/Area. "Flow happens". Those people that see the Velocity=Flow/Area are only looking at the steady state condition. Those that work on big presses normally have more than enough force to make the actuator accelerate so they doesn't make much difference to them. In ALL cases Newton's laws applies Velocity=Flow/area applies only when the pressure doesn't need to change and steady state velocity is achieve but this is a special case of keeping the system going. It doesn't make the system go in the first place.
Tom, look at the PDFs again and try to follow them.
I am getting tired of those that keep on insisting the sun rise in the east and set in the west. That is just how it appears. The sun doesn't rise or set at all, the earth rotates. One can always find a special case that appears to justify their position. Newton's laws always apply. There is no other way to skin tha cat.
Status
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
391
Long story short lost our parameter setup for an indradrive m. I have these files saved as backups but dont know how to open them. Can someone...
907
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,114
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,634
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,605
