Sonicwall VPN
Mar 2012
minnesota
25
So I have a site to site VPN connection created between two locations my office and customers facility. I am using 2 sonicwall soho routers. My office has a static IP address and customer has a dynamic ip address. I can establish the VPN tunnel but can only ping the LAN side of the sonicwall at the remote location. The remote sonicwall also does not let internet access to a PC on the LAN side. I know that my problem is the LAN side does not have access to the outside world but I am not sure how to solve this problem. Any advice would be appreciated
So from your office you can ping all the devices on the LAN side of the remote router? (This is what you are wanting!)
But you are stating that any device on the LAN side of the remote router does not have Internet Access! (So the sonicwall router probably has outbound traffic blocked).
There is going to be much more involved to make this work as (I) think you are wanting it to work.
You will have ports that will have to be forwarded on both routers and you will have to setup the endpoint networks so that the router know how to create the BRIDGE.
Example: (Your Office)- this network might be 192.168.1.100-200
And the Remote Network (Will have to be different) but it could be 192.168.2.100-200 and now you program the endpoints in each router and then the VPN will know what network to bridge.
Sonicwall routers are cumbersome to work with you may want to consider a simpler solution, such as E*** very simple to setup and get working.
I have done it both ways and I must say the latter is super easy.
Please this is just my opinion, I'm sure you will find many other solutions here.
Good Luck!
so I can only ping the LAN IP address of the sonicwall router at the remote location and can not ping anything else.
Example at remote location: sonicwall IP address is 192.168.168.1 and PC is 192.168.168.200 no response from PC and instant from Sonicwall
That's because your pinging the GATEWAY your not actually able to ping the Remote Lan which is 192.168.168.2 and through 252.
So as I said before your sonicwall is stopping inbound and outbound traffic to the internet.
You might want to make sure your remote lan has internet access before you attempt to create a VPN.
Get one thing working at a time.
I am trying to use setup a remote vpn router for external OEM connection. The thing I cannot wrap my head around is the gateway. We use the...
277
Have anyone done this? I don't see why this wouldn't work but I may be missing something too. Getting any recurring account opened is a pain...
1,064
Hello all. When I try to connect to a S7-1200 PLC (Tia Portal v17) which has a CP 1243-1 module that is connected to my clients network I get...
1,521
Hi, We are trying to access a remote PLC for debug, the PLC is networked in with a PC that we can access through TeamViewer. Is there a way we...
2,060
Hi - I am exploring options for cellular enabled hardware VPN / Firewall devices to deploy for remote troubleshooting purposes. I do not have...
772
