speed and time
davidtanwei
Jul 2007
spain
hi,
I currently using a feed pump to drive water from one location to another.
I got a chart that show me the rpm of the motor and the output.
lets the say to run an output of 100ml of water in 1 min. My rpm required is 1000rpm. Can i say that if i run 1000rpm in 30s. My output will be 50ml. Is it linear also?
If a positive displacement pump then it is definitely proportional to speed.
Centrifigul should be
BUT you must assume constant head - which may not be a valid assumption. You need the pump curve if centrifugal.
Dan Bentler
I
As an ex nuke you should know that with centrifugal pumps, the operating point ( pressure and flow ) is determined by the intersection of the pump curve and the system curve. This will not be a linear function because the pressure drop as function of flow is not linear.
actually i already do the experiment similar to the manufacture pump chart showing what rpm produce howm many ml per min.
My chart is definetely different. example...the chart show 1000rpm produce 100ml per min. but my experiment produce 1000rpm with 90ml per min. But i still ok...because my graph still linear and it show good consistent output.
There is variancee in every pump. So the manufacture chart is only a guide to tell you it is linear. I would still need to plot my on chrt for existing pump performance. am i right to say this.
So i also need to plot another chrt to show with this rpm. And with different time. What is my output. So i can have better expectation adjustment in future. am i right?
This verifies Peters statement that you have to derive a system curve.
With system in only ONE configuration. Run pump at varying speeds record discharge pressure and flow. Plot on curve and you have a system curve for that configuration. There are other factors you may have to include such as temperature and specific gravity if you run varying concentrations or different liquids.
Dan Bentler
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
125
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
174
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
150
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
136
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
996
