speed
The ones on the trains in France\Germany do about 180-200Mph
Mitsubishi's new iQ series is 4x faster than the old Q.
As mentioned before, speed is irrelevant. It's going to vary based on the command mix and size of the user program. So to simply choose based on the book speed of a single instruction is just stupid. The device should be chosen based on capabilities and most specifically the project requirements.
Buying a PLC based on rated speed is like buying a car for it's color, ignoring the fact that it's on fire and missing 3 wheels.
PC based systems such as the Beckhoff TwinCat operate extremely quickly due to the use of a PC and their EtherCat range scans the I/O very quickly as well.
Of the shelf PLCs may be slower but it as other people have mentioned, why is the speed so important?
As Crossbow has said it is still dependant on the code and amount of it, for the complete processing scan time. Manufacturers documentation normally quotes the figures for each instruction.
Jon.
You must no do anything that requires speed
tomalbright said:
Speed is irrelevant. What do you want to do, first?
Having special hardware that is necessary too. What difference does it make if the processor is fast but the digital I/O responds in many milliseconds and the analog inputs and output have huge RC filters?
Speed is good but being deterministic important to take advantage of the speed.
The fastest PLCs would be PLC. How can you beat a dual core process with a huge cache? You can slow the PC with a non-deterministic operating system like windows.
S7s are fast. The times claimed for turning and off a bit are very fast. What Siemens doesn't count is all the register shuffling and times wasted openning data blocks. Only about 1 in 2 or 3 instrucitons do real work. This is because it takes multiple instructions do anything because the instructions are only single operand instructions. Normal PLCs have blocks that take several operands so they can take longer to execute but still get the same amount done as three faster simpler instructions.
The biggest question in these cases is "how fast is fast?". As a rule of thumb, an average PLC will get you 2-10ms response time once the system is optimized. Bigger programs will have a longer scan time and smaller programs less. Please specify your application a little further so we can help.
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
109
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
169
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
144
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
134
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
982
