Studio5k backwards compatible?
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all. Is Studio5K backwards compatible? AB gave me a 30 free trial for 30 days. I have a contrologix that is running v.21 however, when I tried to download it it said it was no longer available, since it is such an old iteration. The version they gave me was v.31. Will I still be able to upload from the CPU or am I going to be sorely disappointed? Thank you
If they gave you a serial number for the trial, you should be able to download different versions from their website, but you need to have installed the correct version to match the PLC you are looking at.
You will need the software to match the processor firmware, so for a processor with version 21 you will need version 21 software, it is downloadable if you have an in support contract.
Alan
To add a little clarity, No there is no such thing as backwards compatibility with RSLogix5000/LogixDesigner. As others said, you must install v21. You must install every major version of software for every major of firmware you want to connect to. And you'd be doing yourself a favor to install in order of oldest to newest.
I did just that. Tried to go online via USB however, the "upload" button stays grayed out, even when I drill down to the processor. Linx sees the processor, but it won't allow me to upload. Could this be because I am using a free trial version of software?
That wouldn't be because of the free-trial version.
When you start Studio5K on the splash screen does it show v21 on the bottom with the other version(s)?
My thought is the v21 CPU is not being recognized as a supported version
EDIT: After you installed v21 did you do the MicroSlowest suggested "reboot the PC" that needs done every time you sneeze?
+1
Which is a total PITA if you need to have many of the versions installed - see the pics.
Every now and again I will need at least one of these to open a clients file ....
Just to add to confusion.
We bought Studio 5000 ver 32.
Had a customer call up who had an older machine which had ver 16 (RSLogix5000).
Tried to download that version and always grayed out.
Talking to tech support I needed to download ver 26, then activate ver 26 with my license. This then allows you to download older and newer versions.
Working OK for me so far and I've had to download 5 different versions since then.
I have a V13... and need a 32 bit OS to be able to see the program. It's amazing how they can't (or just don't care) create backward compatibility when other brands have it out of the box.
Hello all, I have Studio5k v23 running on a machine and I am unable to open the software. Every time I try, it acts like it is opening but then...
1,545
What does the backslash and a selected program do in 5k st? I though it was a getter/setter for another program's local tags, much like # in...
1,393
Hello all. My laptop had to be wiped. I am now trying to get all of RS back. AB rehosted all my licenses for me and I have installed RSL5k...
1,880
Hello all. I tried to create a message instruction in RSL5k v.20 and part of the dialog window is cut off. I don't have a ton of experience with...
1,713
Hello all, I have a controLogix running studio5k v.21.03 that I am unable to do a couple of things. First, I cannot perform any online edits. I...
1,517
